Orbz
Oct 19, 2020Aspirant
Several issues with Orbi Mesh Wifi
System: RBR750 router in AP mode with two RBS750 satellites connected via ethernet, both directly to the router 1000/1000 fiber using Nokia Gateway 3 (G-240W-E) ONT with WiFi disabled I have ha...
Mikey94025
Oct 19, 2020Hero
I would start by ignoring the app and any display inconsistencies you might observe there that are not reflected in the orbilogin.com admin website. The multiple SSIDs is normal due to the various mesh locations.
> Phones connected to the network frequently disconnect prompting "Couldn't get IP address" error
You should certainly not be getting any phone errors. What type of phones are these? Do these errors occur when you are using a specific app or browser to access a website (I have an iPhone and am not familiar with ever seeing "couldn't get IP address" error).
Is your Orbi using the default DHCP settings? What, if anything, have you changed from the system defaults?
For the 5Ghz Roku buffering issue, how far away is the Roku from the Orbi base or satellite?
For speed test variances, you can try some of the steps in the community FAQ to isolate where any speed bumps are occuring: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
Orbz
The IP address error has happened on two phones, both Samsungs (Note9 and Galaxy S8+) and happens once every several days. I haven't noticed it happening after using a specific app or website. When clicking on more information about the error, it states:
"Your phone couldn't get an IP address from the router. Try turning the router off, then on again. If the router doesnt belong to you, try contacting the owner. Is the router being used by many people? If all available IP addresses are being used, it may not be possible to connect to the network. It may help to set a shorter IP address lease time in your renter's DHCP settings."
I only have 16 devices connected to the network and have restarted the router several times without change.
I havent changed any DHCP settings from the default. The only settings change I made was to put the router into AP mode in attempt to solve the IP address issue which made no difference.
The Roku is about 20 ft from the router with a wall in between and about 30 feet from the closest satellite with nearly a direct line of sight, just slightly around one corner. Other devices perform just fine around it and I'm showing around -45dbm on the app. The Roku performs better on 2.4GHz when it changes over but there isn't a way I have found to manually select the frequency.
- FURRYe38Oct 20, 2020Guru - Experienced User
How is the RBR connected to the ISP ONT? Using the WAN port on the back of the RBR to the ISP ONT?
If your still having problems with these two devies and DHCP when in AP Mode, i would check with your ISP ONT router since you have a built in router with the ONT. Set IP address reservations there for these two devices.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2...
Be sure your ISP ONTs wifi radios are fully OFF or Disabled.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Check with the mfr of these devices as well. If other devices are working and these two are not, there maybe a problem with these two devices.
The Roku is about 20 ft from the router with a wall in between and about 30 feet from the closest satellite with nearly a direct line of sight, just slightly around one corner. Other devices perform just fine around it and I'm showing around -45dbm on the app. The Roku performs better on 2.4GHz when it changes over but there isn't a way I have found to manually select the frequency. - Mikey94025Oct 20, 2020Hero
Sorry, I can't think of why your two Android phones would be getting these IP address errors. The explanation does not apply to your situation. In Router mode, your phones are getting their IP from the Orbi so even with Double NAT there shouldn't be an issue getting an IP address. One thing to try is to go into orbilogin.com, Advanced... Setup... LAN Setup and add Reserved Addresses for the two phones (check their device line and press Add at the bottom). Again, shouldn't matter but this is one of the only IP-relevant things you can change for your Orbi.
Orbz wrote:
The Roku is about 20 ft from the router with a wall in between and about 30 feet from the closest satellite with nearly a direct line of sight, just slightly around one corner. Other devices perform just fine around it and I'm showing around -45dbm on the app. The Roku performs better on 2.4GHz when it changes over but there isn't a way I have found to manually select the frequency.It sounds like you are at the range limits for 5Ghz (which has greater throughput than 2.4Ghz but less range) and the Roku's auto-selection isn't working at its best for you. Unfortunately if the Roku doesn't give you an option of disabling 5Ghz then there isn't a way on the Orbi side to force it to connect at 2.4Ghz. Shouldn't matter, but for maximum wireless compatibility go to orbilogin.com Advanced... Advanced... Wireless Settings and try changing CTS/RTS Threshold to 2347 for both bands and/or try turning AX mode off for 5Ghz. Maybe one of those settings will affect which band the Roku prefers.
