tuna_ertemalp
Mar 24, 2022Luminary
Shared resources between GUEST and main network?
This might have been discussed elsewhere but couldn't find it by a quick search. I have this old CANON MG8220 printer that can only do 2.4Ghz. It is on the network wirelessly. I have an RBRE960 m...
- Mar 25, 2022
Posted on the Idea board: https://community.netgear.com/t5/Idea-Exchange-For-Home/Shared-resources-between-Main-Guest-6GHz-Iot-networks/idi-p/2208810
CrimpOn
Mar 24, 2022Guru - Experienced User
tuna_ertemalp wrote:
(By the way, getting the printer onto the 2.4/5/6GHz 6E instead of the 2.4GHz 6E-IoT via WPS was an adventure, requiring me to turn off every network except for the 6E so the printer & router could agree to use 6E instead of automatically connecting to 6E-IoT, presumably due to it being the 2.4Ghz-only network. D'oh!)
I found a setup manual for the printer, but it says nothing about connecting to WiFi:
https://gdlp01.c-wss.com/gds/5/0300005415/01/MG8220_GS_U2_V1.pdf
Most devices display a list of WiFi networks and allow the user to choose. The printer should have displayed all three networks (as well as every other WiFi network with a strong enough signal, such as neighbors.) Very puzzling.
Is there a current or planned way to be able to share devices between the main & GUEST networks in the admin webpage of the router? Sort of like a "Make this device visible to GUEST network" checkbox?
The 960 user manual does not mention a guest network setting similar to the original Orbi:
In our current state of paranoia, I could imagine a consensus that "Guests" should have no access to the primary network and thus that option being removed. As it was, the option was "all or nothing". i.e. access only the internet, or access everything. No granularity at all.
I cannot remember Netgear "sharing" plans regarding features in advance. Features simply appear (or disappear) with no warning and no explanation.
tuna_ertemalp
CrimpOn wrote:Most devices display a list of WiFi networks and allow the user to choose. The printer should have displayed all three networks (as well as every other WiFi network with a strong enough signal, such as neighbors.) Very puzzling.
This printer predates widespread use, or maybe even the very existence, of mesh networks. When it showed me the networks it could find, it showed me all three. Sometimes. LOL. At times it would fail to find any network, at times just the IoT and Guest. And, when it did have the main network on the list, selecting it resulted in "multiple access points for that network, which MAC do you want to use" and giving me at least two options where each MAC address was off-by-1 of that of the router's and a satellite's (wut?), I would select the one seemingly of the router that is right next to the printer, and it would think and think, and then fail to connect. Clearly multiple networks coming from multiple points with a variety of MACs wasn't expected by the developers & testers of the FW of the printer baaaaaack in the day. I am waiting for the big supply of inks I have to run out before I buy a new printer. 🙂
Yes, granularity of the access permission is the issue here. The old checkbox should have been per-device, not all or nada.
Tuna
