norbertsf
Jul 08, 2022Aspirant
Should I be getting more speed on Satellites - New RBRE9606(AXE)
Hi, New to the RBRE9606E (AXE). Set-up was easy and haven’t really had any issues except the below. (just had them a week) Firmware V6.0.3.85_3.1.15 about 2,000 ft home Connection on bot...
CrimpOn
Jul 08, 2022Guru - Experienced User
"Poor" means (literally) "not acceptable". Radiant heating systems are tough for WiFi signals to penetrate. I have no explanation for how the backhaul could change from Good to Poor when the units remain in exactly the same location and orientation.
My guess is that this flooring will affect every brand of WiFi system, so it might be time to look into using Ethernet cable to connect satellites to the router.
