roxyroo
Nov 05, 2021Tutor
Should I buy an RBK853 or RBK843S
I am having lots of problems with my current setup. I have an ATT Gateway with two Airtie mesh extenders. Also have a second network running it bridge mode with a AmpliFi HD mesh and two nodes. I ...
Nov 05, 2021Guru - Experienced User
Check the spec sheets for each model here and decide:
https://www.netgear.com/support/
Just in out the model #s and select the Documentaion button.
For ISP modems with built in routers. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
