MB_Love
Jun 17, 2020Apprentice
Should I change channel?
I am wondering if it’s best to select your own channels or just stick with auto setting? While I was in front bedroom I realized we pick up a lot of the neighbors networks and not sure if this could b...
Jun 17, 2020Guru - Experienced User
The problem with selecting your own is if your neighbors wifi is on auto and it switches around, it could end up causing more interference. I usually set mine on auto unless I know my neighbors have set their channel with a set channel and not auto.
Retired_Member
Jun 17, 20202.4Ghz should only be channels 1, 6, or 11.
5Ghz, I've noticed the lower channels perform better. I have mine set to channel 48. You can download an app on your phone to do a scan and see what channels are most popular in your area. Pick a channel that isn't being used a lot.
- schumakuJun 17, 2020Guru - Experienced User
Retired_Member wrote:5Ghz, I've noticed the lower channels perform better. I have mine set to channel 48.
Probably because the lower 5 GHz channels are power restricted, and showing less bars on the mobile .. making them less "attractive" to select manually.
- Mikey94025Jun 17, 2020Hero
I didn't know that about 5Ghz channels, thanks for calling it out! https://metis.fi/en/2018/02/5ghz-channels/
