Thalador
May 18, 2022Apprentice
Should I come back to Orbi?
Hey all. I used Orbi RBK750's for a couple of years and when the firmware disasters began I dumped them (thanks Costco!) for Asus. I do miss some of the features and now with Costco having the 753's ...
May 20, 2022Guru - Experienced User
Let us know what model Orbi you see at Costco please.
Thalador wrote:
I do need to clarify that the new package at Costco is the RBK763's not 753's. Still, seems like they still haven't figured out how to push firmware yet. Here's an idea - don't force it. Let users update when they want.
Thalador
May 20, 2022Apprentice
Are the RBK763x systems having the same firmware issues? That's what Costco is selling
- FURRYe38May 20, 2022Guru - Experienced User
You might check with this user:
They posted having the 760 series however nothing was said about seeing web page access issues. Only thing they were seeing is trying to get RBS750 series synced which seems to be not compatible on the 760 series. I thinking since the FW versions are different from each other, that the 760 wouldn't be effected. Could give it a try and if something happens, I hear Costco has a good return policy.
