LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
Aug 19, 2021Guru - Experienced User
Are you speed testing using the built in speed test app on the RBR or with a external speed test app on the PC and mobile device?
I presume this is a FW issue that seems to stem on this v4 version of FW as we are seeing similar behavior on the RBK7 and 8 series which the CBR750 is based off of.
LJ3000
Aug 19, 2021Guide
I use the Netgear orbi app on iPhone, and I use the built in speed test on orbi login.com and xfinityspeed test website on my hardwired computer. All consistently give me between 500 and 600 mbps for download speed. These tests used to give me between 1200 and 1400 which made me extremely happy with Netgear. Now I’m not getting the speed I pay for and I really don’t want to have to go back to renting from xfinity after spending so much money on orbi.
Also I have an update. An Xfinity tech just checked lines and all looked good for 1 gig speed. He hooked up one of their modem/router devices and we got 948mbps using xfinity speed test. So it is definitely my orbi with the issue. If this is a firmware thing I really hope Netgear gets this fixed because I’m getting so much crap from my spouse for going the expensive orbi route. :(
I upped the CTS from 64 to 2347 but didn’t observe a change in speed.
2.4 ghz is set to 11
5ghz is set to 44
Would factor resetting my device possibly fix this issue?
5ghz is set to 44
- FURRYe38Aug 19, 2021Guru - Experienced User
Please open a support ticked with NG support and let them know what your experiencing. Can reference this forum thread as well.
Thank you.
