LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
atejwani
Aug 20, 2021Apprentice
I am in the same situation!!! Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) was consistently getting 1.2gb - 1.4gb download speeds. Now it below 650mb. Nothing else, besides the firmware updates, has changed.
Netgear Team - Kindly review firmware and provide a fix!!!
Cdhappz
Aug 22, 2021Aspirant
I also have this se speed drop. Was regularly getting 1300-1400 down and now topping out at 600 after the update. I am testing speed at router login as the app is all but useless because it does nothing but crash. Ridiculous that I can not roll back to the previous firmware either. Please fix netgear!
- FURRYe38Aug 22, 2021Guru - Experienced User
Please open a support ticked with NG support and let them know what your experiencing. Can reference this forum thread as well.
Thank you.
- TinslepAug 22, 2021Star
I am currently on hold for Netgear support after submtting support ticket #44990902.
I don't have much faith that I can get through. I have been holding over 20 minutes. It is not giving me a approximate wait time but it was counting down from 6400!
I will hang in there for a while. Any other suggestions?
I did finally get through. They had me do a hardwire speed test on Speedtest.net which was better then what I was getting through the web interface or APP. He had me do a factory reset, which I did but then lost phone connection with him. All my phones are VOIP. Hopefully he call back or I will try back with the case number later.
