LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
Tinslep
Aug 22, 2021Star
OK, after talking to another Netgear support technician I did another hardwired speedtest.net test at 900+MBS which is where I was before software V4.6.3.6. They think it is a issue with the Orbi App, the web interface and the new software. He said he will escalate it to the Orbi team and get a new version of the firmware to fix it.
Hopefully someone from Netgear will respond to this thread.
Aug 22, 2021Guru - Experienced User
Yes, there seems to be a known problem with the Orbi app and onboard Speed test app that are both reporting inaccurate speeds while external speed test app on a wired PC should see to spec speeds.
- LJ3000Aug 23, 2021GuideI got a case number and a representative missed a callback with me. No matter if I’m hardwired or not, download speed doesn’t top 600 no matter what speed test app I use. After scrolling through other posts Sounds like the new fw version is causing all kinds of different problems with connectivity and speed. I tried downgrading to the previous fw version through admin login but once I got to the page to install, I only had a “no”option so I have up. At this point, my internet still works so I don’t want to make my orbi unstable. I really hope that NG fixes this. My speeds are lower and it just isn’t an app issue. My next step is to do a factory reset.
- FURRYe38Aug 24, 2021Guru - Experienced User
Let us know how it goes with a factory reset. Please use a wired PC and a speed test app on the PC to speed test after the reset is done and the CBR is setup again.
