LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
Sep 06, 2021Guru - Experienced User
Factory reset the CBR modem and power it off, I would power OFF the CBR modem and RBS for 5 minutes by pulling the paper adapters from the wall outlets. Power ON the CBR modem and let it sync. Walk thru the setup wizard again using a wired PC and a web browser.
Speed test the wired connection first, then wireless.
Do not speed test with the CBR built in speed test app or Orbi app. Use Ooklas installable speed test app on the PC or your wireless devices.
Turn ON the RBS after testing the CBR.
Tinslep
Sep 06, 2021Star
FURRYe38 Appreciate your info. This is pretty much what tech support had me do. I will try it again on a quiet day.
This is way to much to ask a regular user to do. I have recomended this product to others who now have the same issues.
Netgear should allow a rollback or more ideally a update to Comcast to fix the issues.
This update should have been sent out to a beta group to test before rolling it out to everyone.
- stjames70Sep 06, 2021Guide
well, there is hope. My hardwired speeds are back to normal, and wireless speed is great. Don't use Netgear web interface or mobile app to check speeds (inaccurate). Use Speedtest.net or the corresponding Speedtest app. It gives much better speed readings.
- TinslepSep 06, 2021Star
I followed your reset instructions this afternoon and still no change in wireless performance. Satellite refuses to connect to more then one or two of my 36 devices. Used to connect to 10+.
Tinslep wrote:FURRYe38 Appreciate your info. This is pretty much what tech support had me do. I will try it again on a quiet day.
- LJ3000Sep 08, 2021GuideI started this thread and I checked my satellites and only one or two devices will connect to them too. I don’t know how many people are having this issue but if it’s a small percentage of people based on when we bought our hardware, we will never get a fix. Netgear has missed two scheduled callbacks with me. I am super frustrated with this situation and I agree that Production testing should have been done prior to a firmware release. Although I doubt a big company like Netgear would release an update that crippled the majority of their customers. I work for a large company and stuff is tested so many times that it rarely has issues and if it does, a fix is done immediately or there is a rollback strategy.
- Beantowm111Sep 08, 2021ApprenticeI always assumed the Orbi App correctly reflected speed from modem (also Netgear), given I paid for xfinity gig + speed. I know it drops after that (or at least I have been told that) but now wondering if it ever was correct and if I ever received gig + speed.
