LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
Dellman87
Oct 08, 2021Star
Another day of all day dropped signal while I was at work. Got home, reset it. Worked fine since. This is getting annoying!
Tinslep
Oct 08, 2021Star
I was able to upgrade my RBS 750 satellite software today from the Netgear support page. Neither the CBR or RBS were showing a upgrade available through the web interface.
This drop in speed is a known issue and has been going on way to long! I sure hope we see a CBR 750 upgrade that fixes this soon, but I am on Comcast and they seem to be very slow at updates.
If nothing changes by end of year I will switch to T-Mobile home internet when my contract is up. I will not pay for speeds I am not getting through the CBK 752 Orbi system.
- Dellman87Oct 08, 2021StarI still see 4.6.3.6?
https://www.netgear.com/support/product/cbr750.aspx#CBR750%20(Orbi%20Cable%20Router)%20Firmware%20Version%204.6.3.6- TinslepOct 08, 2021StarI was able to pull v4.6.5.14 for the RBS750 satellite. V4.6.3.6 is still current for the CBR750 modem/router.
- FURRYe38Oct 10, 2021Guru - Experienced User
The CBR doesn't have a FW update as of yet. You can update the RBS to v14. This is supposed to fix odd sync issues seen on the RBS.
Were seeing some better results in v14 FW.
https://www.netgear.com/support/product/cbr750.aspx#CBR750%20(Orbi%20Cable%20Router)%20Firmware%20Version%204.6.3.6- Triggs21Oct 25, 2021StarContacted NG support and have an open support ticket on this product. So incredibly frustrated at this point. They sent me out an RMA (router only) and it does the same intermittent disconnection of internet completely at random points during the day. Ive never been more frustrated with a company in all my life, used to only buy netgear now im not sure I can even recommend them. So i basically have a $600 pair of paperweights that are useless to me (only 6 months old) Had to revert back to my old slower cbk40 to run any sort of stable internet. No drop outs no loss of connection on the older orbi setup. Why is there no solution here?!?
