LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
Triggs21
Oct 25, 2021Star
Contacted NG support and have an open support ticket on this product. So incredibly frustrated at this point. They sent me out an RMA (router only) and it does the same intermittent disconnection of internet completely at random points during the day. Ive never been more frustrated with a company in all my life, used to only buy netgear now im not sure I can even recommend them. So i basically have a $600 pair of paperweights that are useless to me (only 6 months old) Had to revert back to my old slower cbk40 to run any sort of stable internet. No drop outs no loss of connection on the older orbi setup. Why is there no solution here?!?
Dellman87
Oct 27, 2021Star
Preach. I have offline issues every 5 days or so. I just unplug it and plug it back in 30 seconds later and it works again. It's rough when you're watching a show.
- FURRYe38Oct 27, 2021Guru - Experienced User
Have you been in contact with NG support yet?
