LJ3000
Aug 19, 2021Guide
Significant Drop in download speed cbr750
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router Firmware version V4.6.3.6 App version 2.11.0.11 In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had t...
Retired_Member
Jan 16, 2022I have fixed this by switching my main Orbi to AP mode then back to router mode. It did a reset by itself and now the speed are back up to normal after 4 weeks of slow speeds following the update.
Jan 16, 2022Guru - Experienced User
What NG Orbi model do you have?
- Retired_MemberJan 16, 2022I have the rbr 750 triband with firmware v4.6.5.14
And app version 2.13.1.4- CdhappzJan 16, 2022AspirantSo after the new firmware the speed tests have increased back to normal speeds. I however was experiencing a separate issue. My internet was still unstable. Meaning randomly I would get a connected but no internet message on my galaxy s21. Also my family would have major issues using FaceTime on their iPhone. I finally traced the issue to my Samsung TV! Here's the issue and I suspect others may have this problem. The orbi does not have separate selections for 2.4 and 5ghz networks, the router decides internally which device goes on what network. My brand new Samsung smart tv according to samasung operates on the 2.4ghz wifi but when I checked in the orbi it was connected to the 5ghz connection. On the Samsung forums it is stated it is possible to connect to the 5ghz network but you need to connect to the 2.4ghz for stable function. So since I can not do that thanks to the orbis fantastic programing(heavy sarcasm) I have disabled my internet connection through the TV itself and have bypassed it with a firestick. While I'm happy I was able to work around this issue cheaply I am unhappy I had to do this at all. As much as I love the orbi some of the features are not great from a software standpoint and need improvement. Hope this helps others and I will be starting a separate thread for this issue in hopes others might be saved from weeks/months of frustration
- FURRYe38Jan 17, 2022Guru - Experienced User
FYI, it's up to wifi devices to pick and chose where they connect too. Orb only provides the platform and radios to connect too. If devices are dual band, then most devices will choose 5Ghz over 2.4Ghz since 5Ghz offers higher speeds and for some, better performances over 2.4Ghz. So if the Samsung TV recommends 2.4Ghz over 5Ghz this seems that that Mfr needs to tune up there TV FW to work better on 5Ghz. However there maybe a distance issue as well if the TV is too far from the RBR or RBS, it may not switch to 2.4Ghz in which the TV FW seems to still need some tuning. You can help this by changing the power output on the CBR750 on the 5Ghz radio from 100% to 50% or try 25% and see if the TV will switch to 2.4Ghz. Under Advanced Tab/Advanced Settings/Wireless Settings
You can also see if setting CTS to 2347 on the CBR will help.
Also try disabling AX mode on 2.4Ghz on the CBR under the Basic Tab/Wireless settings. Remove the check mark next to 2.4G. Apply the setting.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX as the RBK differs from the CBR750. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
