GWild
Mar 03, 2021Guide
Silly question: but not so funny
Orbi CBR750 Cable Modem / Router How do you turn off REMOTE management? I mean, seriously - there is no OFF button that I can find in the web menus. But when I set up a simple port forward, say por...
- Mar 12, 2021
CBK752 Kit returned for full refund. Problem solved.
GWild
Mar 04, 2021Guide
Oh my gawd... just hung up on support.
An hour wasted, and the "expert" just asked me "What model and brand is the CABLE MODEM are you using?" The entire time I had repeatedly stated the model number was CBR750 ...
Good help is hard to find.
