lagenour
Oct 05, 2022Follower
Simplest way to swapout a AX4200 for RBS20 keeping names and passwords
Getting ready to swapout a AX4200 to replace RBS20 keeping names and passwords intact. Seems I saw a procedure somewhere to do this simply. I'm not an admin, just an old geezer looking for better c...
Oct 05, 2022Guru - Experienced User
Follow the installation Guide. https://www.netgear.com/support/product/rbk752.aspx#docs
We presume you mean the Orbi RBK7 series system?
You can set up the new system using Orbi mobile app on a phone or pad or recommended setup would be to use a wired Pc and web browser. You can use same SSID name and password when presented with this option during the setup routine.
- TC_in_MontanaOct 05, 2022Virtuoso
As FURRYe38 mentioned, you can use the same SSID name and password as on your original Orbi device.
Most times, devices will connect with no issues; however, I have found that on occasion, I may need to turn on and turn off a device to get it to connect back fully. Some devices remember not only SSID and Password, but also the MAC ID of the device it connected to. So turning off/on that device allows it to reconnect correctly. A few of the devices I have had to do this with are Netgear Meural devices and some GE wall switches.
