MiloRetro
Jul 16, 2020Aspirant
Simplisafe Cameras not connecting to new Orbi AX6000 WiFi Internet
I've been unable to get my SimpliSafe cameras linked to the internet via my new Orbi WiFi. The cameras have worked with my last wifi network, a LinkSys EA9300, but they do not link to my Orbi. I know...
Jul 16, 2020Guru - Experienced User
What FW version do you have loaded?
Do you have the prior router?
Are you using the same SSID name and password on the Orib AX as you did on the prior router. If not, you can do this and then see if the cameras will connect.
Disable AX Mode temporarily.
Also be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
