donawalt
Mar 08, 2022Mentor - Experienced User
Since firmware update - new network map?
See attached picture - I have two wired RBS850s and an RBR850 router. Since the update to 4.6.7.13 yesterday, it shows the 3rd floor router into the satellite into the router. Before, it showed both ...
- Mar 08, 2022
I power cycled the satellite on the first floor, left it off for a c ouple of minutes - that fixed it. I was guessing the 3rd floor satellite would then connect direct to the router while the other satellite was powered down, which it did according to the map. I still wonder why, when both satellites are direct connected, it showed one satellite connected to the other instead of to the router?
donawalt
Mar 08, 2022Guru - Experienced User
So a screen capture of what it looks like after the power cycle would be nice.
