Fred_Volkert
Jan 16, 2023Aspirant
Single computer not connecting to internet when on RBS850 satellites
My network is an RBR850 router and 2 RBS850 satellites. When my iMac boots its wifi attaches to the router and can access the internet; later it switches to a satellite located closer and then it can...
- Jan 16, 2023
Fred_Volkert wrote:
Thanks for the rapid response! I checked the iMac in the device list in that menu and clicked the Refresh button; the MAC address stayed the same, so I infer it's hardware-based.
(Not having any "fruit" laptops, I am not really up on iMac, but.....) There should be a specific setting in the Network Settings control panel (or whatever Apple calls it). Hardware or Randomize.
Just personally, I find the whole Access Control business more trouble than it is worth. If someone can guess my 25 character WiFi password, they are welcome to use my internet. I have yet to see a post from anyone remarking, "I just LOVE this Access Control feature." What happens if Access Control is disabled?
CrimpOn
Jan 16, 2023Guru - Experienced User
Fred_Volkert wrote:
but is still listed on the network.
Does the Attached Devices (web interface) or Connected Devices (Orbi app) show the device moving from the router to the satellite?
Fred_Volkert
I've been watching it move using the Orbi app on my phone. Rarely, it boots into the satellite, and then it fails to connect to the internet from start. Usually it boots into the router, and is ok until it moves into the satellite.
