openupshop78
Nov 18, 2019Aspirant
SIP ALG
Hello, I work in the VOIP field and realized the SIP ALG option isn't working correctly. I disabled it, under WAN setup and my tests are still showing the SIP ALG option is still enabled. My Or...
Nov 18, 2019Guru - Experienced User
Is this for the RBK852 system?
What FW version is currently loaded?
- openupshop78Nov 18, 2019Aspirant
Yes, this is for the RBK852 new Orbi AX system. I am on FW V3.2.7.2_1.1.7
- FURRYe38Nov 18, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update then disable SIP ALG and test again?
