openupshop78
Nov 18, 2019Aspirant
SIP ALG
Hello, I work in the VOIP field and realized the SIP ALG option isn't working correctly. I disabled it, under WAN setup and my tests are still showing the SIP ALG option is still enabled. My Or...
openupshop78
Yes, this is for the RBK852 new Orbi AX system. I am on FW V3.2.7.2_1.1.7
Nov 18, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update then disable SIP ALG and test again?
