ezjoe21
Mar 13, 2023Aspirant
Slow LAN speeds on RBR850, half of what I got on my RBR50
My RBR50 finally gave up the ghost. The firmware was corrupt and I could not figure out how to telnet the firmware to it any longer. So...I replaced my system with an RBR850 and two satellites. The w...
CrimpOn
Mar 13, 2023Guru - Experienced User
The WAN (Internet) port on the RBR850 router is a 2.5GB Ethernet port. When the Orbi Speed Test reports 1.4GB, that is an indication that the link between the cable modem and the router is running at 1.4GB.
My guess is that the computer has an 'ordinary' Gigabit Ethernet adapter. That means when the computer is connected to anything, the maximum Ethernet link that can be negotiated is 1GB. In practice, the maximum throughput on a 1GB Ethernet link is slightly less than a full gigabit because of the overhead in Ethernet transmission. 950ish is pretty typical.
I agree entirely, when
- the modem is delivering 1.4G to the router
- the Orbi router port is 1G
- the computer port is 1G
Then the measured speed at the computer should be slightly under 1G ("950ish") A speed of "half that" is unacceptable. I can think of nothing that would explain how an 850 would produce less speed than a 50. None.
Fortunately, a new purchase comes with 90 days of "complimentary support" (as opposed to, "you bought it. YOU figure out how to make it work.") How about registering the new system with Netgear at my.netgear.com and have them explain this?
- ezjoe21Mar 14, 2023Aspirant
I opened a ticket this morning. Level 1 escalated to Level 2....that is as far as I have gotten. No response yet for L2.
- StraqMar 15, 2023NETGEAR Expert
Sounds good. If you have a chance/opportunity please try the above comment from Stra_q
- WRSORBIMar 15, 2023Luminary
I would be very interred to hear what L2 has to say. I experienced a very similar condition ever since I upgraded to Windows 11 22H2. When I revert back to Windows 11 22H1, no problem. My NIC is set to 1Gbs - no auto negotiation
