ezjoe21
Mar 13, 2023Aspirant
Slow LAN speeds on RBR850, half of what I got on my RBR50
My RBR50 finally gave up the ghost. The firmware was corrupt and I could not figure out how to telnet the firmware to it any longer. So...I replaced my system with an RBR850 and two satellites. The w...
Mar 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
ezjoe21 wrote:
My RBR50 finally gave up the ghost. The firmware was corrupt and I could not figure out how to telnet the firmware to it any longer. So...I replaced my system with an RBR850 and two satellites. The wifi is faster than what we experienced before and seems to be more seamless. However, I used to get 950ish Mb/s to my desktop in my office, and now I get about half that speed. If I swing the cable for my office directly to the cable modem, I am back in the 950 range as expected. Speedtests run from the Orbi management screen show speeds around 1400+ Mb/s. Any ideas on what would be causing such a drop in speed from an RBR50 to an RBR850?
- Stra_qMar 14, 2023Aspirant
Something that can possibly help is to ensure that the Ethernet Network Adapter is set to link speed to 1Gigabit. It might be set to Auto Negotiation. Please let us know if this helps.
You can change the link speed from Auto Negotiation to 1000Mbp/s by going to device manager. Then click on Network adapters and double click you ethernet adapter. Then go to advanced tab and click link speed or speed/duplex.
