BadBunny78
Jul 06, 2022Follower
Slow Local Wifi/Fast Wired Internet RBK852
Hello. Just upgraded my internet service to Gigabit and having some issues with my Wi-Fi speeds. I have 1 Router and 1 Satellite. When I plug my laptop directly into the RBK852 router with a Cat6 c...
Jul 07, 2022Guru - Experienced User
Wifi speeds won't be as fast as wired speeds. There's a lot of reasons but mainly it comes down to network overhead, wireless interference, obstructions, and device limitations.
For example, the 8 series (your router) has a 1200mbps 2.4ghz and 2400mbps 5ghz fronthaul. But thats with a 4x4 antenna setup. Most devices (phones/tablets/laptops) are 1x1 or 2x2 antennas. So the best possible connection is at 1200mbps. But thats just link speed. Actual throughput tends to be around 55-65% of link speed. that'd put your around that 600-800mbps range for actual throughput. And thats if you're connected at the maximum rate and don't have much interference in your area.
I'd take a read through duckware's article on it. Its a bit in depth but helps explain it really well.
https://www.duckware.com/tech/wifi-in-the-us.html
