RSPS1
Sep 18, 2020Follower
Slow RB850
I have a new AX6000 with the router and satellite on opposite ends of the house. The house is fairly small, 2400 sq. ft. At the satellite end a wifi strength meter says very high speed, but when I tr...
Sep 18, 2020Guru - Experienced User
What device are you using at the RBS?
What are you trying to download to this device?
Is Armor enabled on the Orbi RBR?
What happens if you connect to the RBR?
I recommend that you need additional help, you should find a nieghbor, friend or family member to help you out with this.
