ChaseA2017
Jul 31, 2023Aspirant
Slow RBR750 Speeds
I’m having the exact same issues to include the 90%drop in speeds with my RBR750. I’ve consistently had great 900+ speeds with my router and satellite. Service - Frontier FiOS 1Gig Arris Router (...
ChaseA2017
Aug 02, 2023Aspirant
Thanks for responding back. The answers are below.
- V4.6.14.3_2.3.12
- Arris NVG468MQ (FiOS)
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Cables are good to go. Never had issues with speeds up until recently. Using CAT 6.
How many RBS are deployed?
- 1
- Single Story / ~1700sq ft.
What is the distance between the router and
- Roughly 40ft separated by a single wall
satellite(s)? 30 feet or more is recommended in between RBR
and RBS
️ to begin with depending upon building materials when wirelessly connected.
Does this happen with the RBS turned OFF?
- Yes
Does this happen with both wireless and wired devices?
- Yes
What channel configurations are currently set on the router?
- 2.4ghz (AUTO)
- 5ghz "48"
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
****Changed this setting and now rebooting Router & Sat. Fingers crossed, this works...
Factory reset and setup from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Aug 03, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
