J00101101001001
Apr 07, 2021Aspirant
Slow Speed Issues with Orbi RBR750
I am having speed issues with my Orbi RBR750. I have a Arris SB8200 modem connected to it using link aggregation. My speed package through Xfinity is 1.2gbps. Speed Test Details: - When performi...
Apr 07, 2021Guru - Experienced User
What your seeing is expected. Near 900Mpbs will be to spec for your wired Mac Book if it's using a 1000Mbps connection rate, unless you get a 2.5 or 5Gb USB-C to Ethernet adapter, then you may need more speeds.
For your iphone and wireless devices, these are limited by there antenna design. Most iphones and pads are 2x2 in design. So these will cap out at around 400-500Mbps. Even on AX wifi. Devices with 4x4 antenna designs will see higher speeds. Just depends on there design and support.
