J00101101001001
Apr 07, 2021Aspirant
Slow Speed Issues with Orbi RBR750
I am having speed issues with my Orbi RBR750. I have a Arris SB8200 modem connected to it using link aggregation. My speed package through Xfinity is 1.2gbps. Speed Test Details: - When performi...
Apr 07, 2021Guru - Experienced User
A couple things. The RBR750 has wan link aggregation. But that allows the router to get >1gig speeds from the modem.
If if you're using wan port aggregation, you don't have the ability to lan port aggregate as well. So your hardwired devices won't hit >1gig.
In terms of wireless, alot depends on your device. You say your phone is "capable of gigabit". What phone is it? As well as what link speed are you connecting at? (hint, link speed is not the same as actual thoroughput)
Are you using 2.4ghz or 5ghz?
