J00101101001001
Apr 07, 2021Aspirant
Slow Speed Issues with Orbi RBR750
I am having speed issues with my Orbi RBR750. I have a Arris SB8200 modem connected to it using link aggregation. My speed package through Xfinity is 1.2gbps. Speed Test Details: - When performi...
J00101101001001
My phone is a Gallaxy Note 10+ 5G. I checked the link speed and it says 1.0 Gbps. I then performed a speed test and it hovers around 400 Mbps.
Mikey94025
Apr 07, 2021Hero
J00101101001001 wrote:My phone is a Gallaxy Note 10+ 5G. I checked the link speed and it says 1.0 Gbps. I then performed a speed test and it hovers around 400 Mbps.
Link speed is the theoretical maximum, not what you're actually transmitting. Your actual speed will vary depending upon the wireless connection (2.4Ghz, 5Ghz AC, 5Ghz AX, etc.).
For general such speed diagnosis steps see the community FAQ: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944. At the bottom are some references link this one about actual wireless speeds: https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
