bmillz
Dec 15, 2023Follower
Slow speeds on RBR760
Hello, I’m in Canada, and have a shaw gen 2 XB7 wifi modem set up in the basement. Previously, I connected my ps5 (located 1 floor directly above) to this through 5 ghz wifi. This was giving me about ...
Dec 15, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Basements are not recommended places for the RBR. All that concrete and steel will inhibit good signal travel and cause problems.
