AlexHobson
Oct 24, 2024Aspirant
Slow speeds Orbi RBK763S with Virgin Hub 5
Hey Guys, I am having trouble with speeds through Orbi RBK763S, My setup is as follows: In the house I have a Virgin Media Hub 5 upstairs that is hard wired into the Orbi with a Cat 6 cabl...
Oct 28, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
AlexHobson
Oct 29, 2024Aspirant
Hey,
Thanks for your reply mate
So in terms of firmware, they are all on the latest update which is V6.3.8.5
Im not sure exactly the size of the house, but its a small 2 bed house on a terraced street, so as you can imagine there are quite a few networks surrounding
The distance between router and satellite is around 32 feet
I haven’t actually tried using the virgin router in modem mode, that will probably be my next test!
The only confusing thing is that it worked absolutely fine on my older RBR50 setup, i dont understand how the performance is so much worse on a newer system?
- FURRYe38Oct 29, 2024Guru - Experienced User
AlexHobson wrote:
Hey,
If you can get a size in sq ft, would be good to know this.
Try bringing all RBS to near or same room as the RBR and take note of the WLAN Backhaul speeds seen at the RBR.
Also try swapping RBS with each other to see if problem follows or remains at the remote location.
Definitely give this try as the ISP router has wifi built in and either needs to be disabled or ISP router but in to modem only mode.
