AlexHobson
Oct 24, 2024Aspirant
Slow speeds Orbi RBK763S with Virgin Hub 5
Hey Guys, I am having trouble with speeds through Orbi RBK763S, My setup is as follows: In the house I have a Virgin Media Hub 5 upstairs that is hard wired into the Orbi with a Cat 6 cabl...
User763
Oct 29, 2024Aspirant
Furry, the 760 is tri-band with a dedicated backhaul.
If you get good WiFi speeds from the RBR, then I would suggest to start with a single satellite, make sure if is connected with 5GHz to the RBR (check the "Attached Devices" page and the "Show Statistics" under "WLAN Backhaul"). Even if only temporary, I'd also suggest to try with a wired backhaul to see if that solves the problem.
Oct 29, 2024Guru - Experienced User
I stand corrected. Yes it is a tri band system:
Orbi AX5400 Router and AX5400 Satellite
(600+2400+2400Mbps)
