FreekaaY
Nov 22, 2023Follower
Slow Speeds wirelessly
I have a ORBI AX4200 WiFi 6 High- Performance Router (RBR750). Wirelessly or direct connected to the back of one of the satilites, I don't get the speeds I am suppose to be getting. Connected to the Satilite I get half the speeds but wirelessly I don't get nearly what I am suppose to be getting. Can some help?
Thanks
This requires more detail.
- What speed has the Internet Service Provider (ISP) contracted to provide?
- What is the make/model of the ISP device that the Orbi RBR750 router is connected to?
- What speed is reported by the Orbi router itself (on either the Orbi web interface or the Orbi 'app'?
- Has a computer been connected directly to the ISP device and the speed measured?
- What are the observed speeds?
- What specific devices are being used to measure the WiFi speed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Thanks
