joseph1r
Apr 29, 2023Aspirant
Slow speeds
I have a GB connection to the house from AT&T, My I am running CAT5e and CAT6 in my home. All my rooms are getting GB wired speeds except for my office which has a Gigabit 8-port 300 Series SOHO Un...
joseph1r
Thank you for your response, however, I do not feel that it is applicable yet.
I have two computers in my office that have the same issue. The cables are new, and the patch cables in the closet look fine as well.
I have purchased a new gigabit switch which should arrive on Monday. I will switch that out and see what occurs.
If I experience the same issue, then I would agree with your assessment.
If I do not experience the same issue, then this would definitively point to the Netgear as the problem.
CrimpOn
Apr 29, 2023Guru - Experienced User
Any number "close to, but under 100Mbps" sort of "leaps out". (If the speed had reported 102Mbps, for example, it could not be the auto negoriation process.)
An easy test (but probably not convenient) would be to connect that computer directly to the Ethernet LAN port on the back of the router. (no patch panel, no wiring inside the walls, no switch, no patch cables). Alas, moving desktop computers around is simply not practical.
Please report "what happens".
