DT33's avatar
DT33
Slow upload Speed RBR750
Hello Everyone,
I have a question and I can't get it done in the right way.
Model Version: ORBI RBR750
Firmware: latest V4.6.9.11
Environment: Orbi as modem and router, fiber connection 1gbps
When I removed the modem from my supplier everything works fine but the upload speed is very slow. I have a 850 (almost max) download speed through the cable and 150 (1/6 of the max) upload speed.
I saw some solutions to update to the latest firmware version but it is still not good. Anyone else with the same problem? I saw some posts on reddit as well about the same issue but no solution unfortunately.
Can anyone help me?
  • Try increasing the MTU size. Setting can be found on the web GUI under >> ADVANCED >> Setup >> WAN Setup
    • DT33's avatar
      DT33
      Thanks ekhalil I will try this when I will be at my home tonight! Of course I will update you if this works or not.
