tigerisak
May 25, 2021Guide
Slow WIFI on RBR850
Hi. I have a RBR850. Getting 1gbit/1gbit hard wired. Only getting 360 mbit wifi. What Firmware version is currently loaded? V3.2.18.1 What is the Mfr and model# of the Internet Service Provid...
tigerisak
May 25, 2021Guide
Sorry. I forgot to mention that Im using my Macbook Pro from 2020 as my primary wifi-device. And Im getting the same speeds. I used to get around 900 on this Macbook when using the Orbi. But not for the last months..
May 25, 2021Guru - Experienced User
What are you connection rates seen on the MBP at the RBR with RBS turned OFF?
- tigerisakMay 25, 2021Guide
Getting the same speeds when turning of the RBS.
- FURRYe38May 25, 2021Guru - Experienced User
What are you connection rates seen on the MBP at the RBR with RBS turned OFF? This is seen on the wifi connections list when you press the option button on the MBP and left click on the wifi icon on the top tool bar of the screen.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Getting TX 1.300 mbit PHY: AC when turning the RBS OFF and also when turning the RBS ON.
