tigerisak
May 25, 2021Guide
Slow WIFI on RBR850
Hi. I have a RBR850. Getting 1gbit/1gbit hard wired. Only getting 360 mbit wifi. What Firmware version is currently loaded? V3.2.18.1 What is the Mfr and model# of the Internet Service Provid...
May 25, 2021Guru - Experienced User
Do you have Traffic Meter enabled by chance on the RBR?
For setting 40Mhz only, just take the check mark out of the check box for 20/40Mhz Coexistance and this sets 40Mhz only. Apple the change.
How close are you to the RBR when speed testing? 6-10 feet range?
Make sure Enable WMM is enabled and try setting 2347 for CTS. Under Advanced Tab/Advanced Settings/Wireless Settings
Just checked mine when I got home. 1Gb/50Mbps ISP service.
v1 FW.
Manual channels 11 and 48.
40Mhz only.
CTS 64
Armor and Traffic Meter not enabled.
WMM enabled. Preamable Mode: Auto
Mac Book Pro 2018 placed near the RBR, 4 ft:
Checked my Iphone 12 Max as well:
Pretty good for sitting right next to the RBR. I presume as distance gains in between the devices, speeds will have some degradation which is to be expected.
- tigerisakMay 25, 2021Guide
I did set it to 40 MHz only.
Changed the CTS
WMM enabled
Preamable Mode: ShortTraffic meter: Off
Still the same issue. THe MBP is 3 ft from the RBR.
- FURRYe38May 26, 2021Guru - Experienced User
Have a different laptop to test with?
You might try downloading v1 FW manually using a wired PC on the RBR, factory reset and test again...
Possible your RBR is faulty.
- tigerisakMay 26, 2021Guide
Tried iPhone, iPad and a Lenovo laptop. Same issues.
Please advise on how to "downgrade".
