EelcoR1973
Jan 03, 2024Follower
Slow wifi speeds o Orbi RBR850 router & satellites
System is #Orbi #RBR850, one router, two satellites Since a few days (probably after shutting down the power due to home renovations) my wifi is extremely slow (80-90 mbps). Recently we were able to...
Jan 03, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Be sure the wireless devices are connected to the nearest RBR or RBS before speed testing. Disable the wifi radio on the wifi device for 5 seconds then re-enable it while standing near the RBR or RBS.
