Microducks
Aug 17, 2024Aspirant
Slow wireless speed RBR850
The Speed between my RBR850 and Spectrum Router is well over 1GB (my plan is 1GB). But wirelessly (in the same room as my RBR850 Router) and everywhere else in the house my speeds are only 300-500 mb...
Aug 18, 2024Guru - Experienced User
What wireless device are you speed testing with?
Be sure that the device is acutally connected to the RBR and not a remote RBS by disabling the wifi radio on the device for 5 seconds then re-enable it. Device should connect to the RBR. 4-6 feet distance should be best from the RBR.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Microducks
Aug 18, 2024Aspirant
Cell Phone when I'm checking the areas around the house. Laptop when in the same room as my RBR (I am assuming RBR means the Router and RBS means the satellite). Desktop PC while across the house. Before I posted the original post I had reset the Router and Satellite and updated them (v7.2.6.31).
Modem - Docsis 3.1 (ET2251)
I have 1 router and 1 Satellite
House 1900sqft
- CrimpOnAug 18, 2024Guru - Experienced User
The same cell phone and laptop, connected by WiFi to the same Orbi 850 recorded speeds of 700-900Mbps with AT&T service, but now record speeds of 300-500Mbps when connected to Spectrum?
The only thing that has changed is the ISP is now Spectrum when it was AT&T before?
- FURRYe38Aug 19, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰For that size of home, may have too much wifi signal going on:
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Brand and model# of cell phone and laptop?
House 1900sqft
