nagendraprasath
Jan 11, 2021Aspirant
Slower Speeds after firmware upgrade
I recently upgraded my orbi routers to firmware version V2.7.2.102 (both router and satellite) and noticing slower upload/download speeds over WiFi. my internet connection is about 300Mbps and my wi...
LaceyWest
Aug 16, 2021Aspirant
Same Issue I was getting over 1gig i update and now my speed is 300mbs wired
Aug 16, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- LaceyWestAug 16, 2021Aspirant
I did after i saw your reply and now my speed is 82mbps and my download light is flashing.
I have the CBR750 + 1 sat- FURRYe38Aug 16, 2021Guru - Experienced User
I recommend you post about this over in the Orbi with Cable modem forum and lets start a new thread there.
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
