Bergynet
Dec 07, 2020Aspirant
Slower speeds for AX4200 on gigabit
Hello friends. I recently purchased the Orbi AX4200 (Rbk750) from Costco. This is the WiFi 6 orbi router with 2 additional satellites making a 3 piece set. I’m running a gigabit plan through my ser...
Mstrbig
Dec 12, 2020Master
check your cabling to make sure there is no cat5 cable present. Cat5e and above is suggested.
Under Advanced Wireless settings uncheck Enable 20/40 MHz Coexistence and check Enable WMM (Wi-Fi multimedia) settings (2.4GHz b/g/n/ax).
I have AX mode enabled
