artsoto23
Mar 19, 2021Aspirant
Slower than advertised speeds AX4200?
Hello, Newbie here, I just bought this ax4200 RBR750, and was wondering why my speed is not where it should be, I have hooked up directly to my fiber box, not a modem, (I was told) this fiber box does...
Mar 20, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers/ONT the NG router is connected too?
What Speeds up and down do you pay for from your ISP?
15 feet between the RBR abd RBS is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
I've seen speeds around 600-700Mpbs with my 12Max on a 1Gb ISP line. Thats about the higher limit for these models I believe.
- artsoto23Mar 20, 2021AspirantV3.2.16.22, I'm paying for 1 gig up/down, DTC communications is my isp provider, the "fiber box" has no info on it, literally a black box with lights in front of it, and ethernet ports in back of it, of which I have my orbi router connected to it via ethernet
- FURRYe38Mar 20, 2021Guru - Experienced User
Are you getting near 900Mpbps at the RBR with a PC or laptop?
Turn OFF the RBS and connect the iphone to the RBR. Speed test with Ooklas installable speed test app on the phone.
Also I mis-spoke about iphone speeds, They will max agout at around 400-500Mpbs, not 600-700. This is due to the antenna configuration on the iphones. 2x2. IF they supported 4x4, then the speeds would be higher.
Here is a test with my Iphone 12 Max and RBR 850:
- artsoto23Mar 20, 2021AspirantHard wire to my MacBook, I'm getting 850 down 970 up, what is rbr and RBS, like I said newbie here
