Puch96
Feb 22, 2023Guide
Slower Wifi download speeds compared to upload speeds
Hello all. I searched this formum but not sure if I found an answer yet. I have Orbi Mesh System RBK852 I have ATT Fiber 1G service up/down. I configured my ATT router to IP passthrough and ...
Puch96
Feb 28, 2023Guide
I'm not sure MIMO support on devices, but the devices I'm using to test are all ax compatible.
Saamsung S21 ultra, S23 ultra, iPhone SE 2020.
The strange thing I don't understand is why I'm getting significantly higher uploads vs. downloads on wifi.
I am testing connected to the main router about arms length away...
I can try to disconnect the satellite to see if there is any change. But nothing has changed on the network (i.e. router/satellite locations, etc) except for noticed lower download speeds vs. upload speeds when connected to main router.
Feb 28, 2023Guru - Experienced User
General suggested testing distances from the RBR or RBS would be about 6 to 10 feet.
Please give feedback to the questions presented as well.
- Puch96Feb 28, 2023Guide
Just tested about 6 feet from main router.
595 down
866 up.
- Puch96Mar 03, 2023Guide
Update: I just tested using fast.com and download speeds are around 800Mbps and upload around the same. Maybe an issue with Ookla speedtest app.
- FURRYe38Mar 03, 2023Guru - Experienced User
Try changing test servers with in the Ookla app. Some servers around your area may or may not be capable of testing at spec speeds, or busier than others.
