PaulO1804
Jan 20, 2021Aspirant
Solid magenta LED on new RBK753
Hi there, pretty frustrated at the moment. I replaced my working, but struggling BT Whole Home Wi-Fi mesh with the RBK753 and can’t get it to connect to the internet - the router just shows a solid ma...
PaulO1804
Jan 24, 2021Aspirant
FURRYe38 ‘Sometimes browser caches can get hosed up and there not cleared out normally by the system so it's best to clear out any browser caches before starting a setup process.’
Ok thanks, that makes sense and lesson noted for future
‘I would set the ISP modems DMZ up for the IP address the RBR is given so that you can avoid any connectio problems while having two routers online at the same time.’
I have to admit I don’t know what this means. But I’ll have a dig around later and see what I find
PaulO1804
Jan 25, 2021Aspirant
FURRYe38 I’m gonna close this and mark it solved and come back if I have any more issues. I probably won’t get a chance to fiddle around with the routers for another few days.
Thanks a lot for your advice, which really helped me sort this out
- FURRYe38Jan 25, 2021Guru - Experienced User
Enjoy. :smileywink:
