TheBlair21
Sep 27, 2021Tutor
Solid Magenta Light on RBR850 with no Internet
Hey, everyone I am losing internet, and then I am finding a solid magenta light on my router only, no light on the satellite. I have the RBR850 (Orbi WIFI 6 with one satellite). My modem appears ...
TheBlair21
Sep 27, 2021Tutor
-V4.6.3.16_2.0.51
-Using my own Modem - Netgear CM1000
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
-Yes, I have had to powercycle everything several times. Three times last night and twice today, already. Turn off the Modem, Router, and Satellite. I let them sit. Then turn on the Modem until it completes its cycle. Then turn on the Router, followed by the Satellite. It works each time, but seemingly at random intervals, I notice there is no longer internet through the network and I find the Router with a Magenta light.
Be sure your using a good quality LAN cable in between the modem/ONT and RBR. CAT6 is recommended.
-Using a Cat6 cable.
-I should note, nothing has changed. This began seemingly out of the blue. Same Modem, cables, Satellite position. No changes to my knowledge, and I have not had issues like this before. Internet has always been strong and fast. I believe the firmware updates on its own, so I am curious if it has something to do with that. However, my scope of knowledge in networking is a bit limited.
Sep 27, 2021Guru - Experienced User
One indiacation is that when the RBR is PINK, there is a problem at the modem. IF this came out of the blue and just started, possible ISP signal issue or modem issue.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
How long have you had the Orbi updated on v16?
- TheBlair21Sep 27, 2021Tutor
Thanks for the quick responses!
The ISP did a check, and from what they are seeing, everything looks fine. I should note, in the past if there has been a dropped signal, once the Modem refreshes the Orbi seems to come back online (Magenta light disappears and I have internet). When this issue is happening, the Modem is up and running, but the Orbi shows a Magenta light and it stays with no internet. All that is to say if I am trusting the lights on my Modem, it is working fine.
As far as how long, I'm not sure. I believe it updates automatically, so whenever the update was released? Everything was working fine until late last week, perhaps. Is there a thought of changing from this firmware version? And if so, how would I go about that?
- FURRYe38Sep 27, 2021Guru - Experienced User
v16 released on the 17th, however not sure if your was auto updated around then or afterwards.
You might factory reset the RBR and set it up from scratch and see if this helps any.
I would leave Armor, Access Controls and Traffic Meter disabled.
- r1psOct 15, 2021Aspirant
I have an RBR850 with goggle fiber plugged directly into the modem. And mine started doing this out of the blue as well, i will loose internet and will have to unplug and replug the router back in. The google fiber jack is showing a blue light the whole time.
