AllDueRespect
May 03, 2024Initiate
(SOLVED) Connect ORBI 750 to QUANTUM Century/Brightspeed no PPP
My device is actually an RB750 mesh but there was no model pull-down. I decided to post this for any of you trying to bypass the Century Link / Brightspeed gateway and connect directly to their ONT....
May 03, 2024Guru - Experienced User
Thanks for posting this.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
