MK2022
May 04, 2023Aspirant
Some apps intermittently not connecting to RBR / RBS750
Configuration: RBR750 and RBS750 via ethernet backhaul; AP mode Firmware: V4.6.14.3 Since few weeks, some applications on my Android 13 phone intermittently don't work while on the Orbi WIFI, bu...
May 04, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Make sure that any MAC Address Randomizer is disabled on mobile devices while at home:
Orbi would not be blocking anything while in AP mode. Check your host router or ISP services, DNS and configurations here.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- MK2022May 05, 2023Aspirant
Hi FURRYe38 ,
I've just posted a reply, but can't see it now...
I proceeded with a network restart, als did a network reset on the phone and disabled randomized mac. ~24 hours later, the problem occurred once again...
For your information, I am using CAT6a network cables; the modem is a SagemcomFast5359; and no factory reset since latest FW upgrade.
- FURRYe38May 05, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
