rchamrick
May 13, 2024Aspirant
Some devices cannot connect to ORBI RBRE960
In February, I upgraded to the RBRE960 router with one satellite. My new home has many smart features (including 57 smart lights, smart shades, ring floodlight network + additional ring devices, sma...
May 13, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
- rchamrickMay 13, 2024Aspirant
V6.3.7.10
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?I don't know. I'll have to see if I can figure that out by looking at the equipment.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What is the distance between the router and satellite(s)️?
30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wired or wirelessly connected.
It's just under 50 ft. I can try moving them closer together, but the RBR and the RBS seem to be connecting with each other fine. The "Network Map" on my app always shows a connection between the Internet -> RBR960 -> Orbi Satellite. Some of the devices that drop typically connect to the RBR and some typically connect to the RBS.
I'll try this. I also have wifi available from the ISP router, so I may see if I can get my devices to connect to it.
Thanks for asking this. I now realize why the Lutron Shades always work. They are connected to the RBS via ethernet cable. Same with the Ring network.
What channel configurations are currently set on the router?Where do I find this?
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...Will do. Is this why there are 50 jillion (slight exaggeration) non connected "Apple" devices on my device list?
- FURRYe38May 14, 2024Guru - Experienced User
rchamrick wrote:
V6.3.7.10
I'd review updating FW:
Let us know if you can get this information please.
Lets try 40 feet.
If the ISP has a router here, then you'll need to disable all wifi radios on this router to help lower interferences.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Does this happen with both wireless and wired devices?
On the RBRs web page.
- rchamrickMay 14, 2024Aspirant
V6.3.7.10
Thanks. I used the app to check firmware and it says it's the most recent version.
Calix GigaSpire BLAST Model: u6.1 GS4220E
Lets try 40 feet. Will give it a shot.
Couple of options,
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS8...
Try option #2 first...I'll contact the ISP and get their help disabling the wifi on their device. The ISP installer said this was a good idea to do after we got the Orbi installed.
The Router IP address is 10.0.0.1. When I go there, it tells me the connection is not private an askes me to sign in. When I provide my NG ID and password, nothing happens. At one point there was a message that said something like "your router address has been set to 10.0.0.1 to avoid conflict with ISP."
I did do this but my phone will still not connect to the NAME SSID. It will connect to the NAME-GUEST ID.
This morning my computer will connect to NAME-IoT and NAME-Guest and both have internet. It will also connect to NAME, but when it does it says there's no internet. I don't understand at all why different SSIDs on the same router have different results. 😕
I greatly appreciate your help with this. It's super frustrating!
