rchamrick
May 13, 2024Aspirant
Some devices cannot connect to ORBI RBRE960
In February, I upgraded to the RBRE960 router with one satellite. My new home has many smart features (including 57 smart lights, smart shades, ring floodlight network + additional ring devices, sma...
rchamrick
V6.3.7.10
I don't know. I'll have to see if I can figure that out by looking at the equipment.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and satellite(s)️?
30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wired or wirelessly connected.
It's just under 50 ft. I can try moving them closer together, but the RBR and the RBS seem to be connecting with each other fine. The "Network Map" on my app always shows a connection between the Internet -> RBR960 -> Orbi Satellite. Some of the devices that drop typically connect to the RBR and some typically connect to the RBS.
Does this happen with the RBS turned OFF?
I'll try this. I also have wifi available from the ISP router, so I may see if I can get my devices to connect to it.
Does this happen with both wireless and wired devices?
Thanks for asking this. I now realize why the Lutron Shades always work. They are connected to the RBS via ethernet cable. Same with the Ring network.
What channel configurations are currently set on the router?
Where do I find this?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Will do. Is this why there are 50 jillion (slight exaggeration) non connected "Apple" devices on my device list?
May 14, 2024Guru - Experienced User
rchamrick wrote:
V6.3.7.10
I'd review updating FW:
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?I don't know. I'll have to see if I can figure that out by looking at the equipment.
Let us know if you can get this information please.
Lets try 40 feet.
If the ISP has a router here, then you'll need to disable all wifi radios on this router to help lower interferences.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
What channel configurations are currently set on the router?Where do I find this?
On the RBRs web page.
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...Will do. Is this why there are 50 jillion (slight exaggeration) non connected "Apple" devices on my device list?
