Phil_T_AU
Sep 18, 2021Tutor
Some devices lose wifi after a day and then won't reconnect
Hi, help smart folks - random wifi issues impating only a couple of devices that lose wifi after a while and don't reconnect... I have a RBR750 and 2x RBS750 satelittes in a large 5 bed house...
Sep 18, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s).
