Phil_T_AU
Sep 18, 2021Tutor
Some devices lose wifi after a day and then won't reconnect
Hi, help smart folks - random wifi issues impating only a couple of devices that lose wifi after a while and don't reconnect... I have a RBR750 and 2x RBS750 satelittes in a large 5 bed house...
Sep 18, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s).
Phil_T_AU
Oct 04, 2021Tutor
Hi Folks,
After going back and forth with netgear support numerous time, I've given up.
I have returned my orbi for a full refund from where i bought it and bought a ASUS mesh wifi instead - which is working reliably.
The 2 issues that lead to this point were:
1) the troubleshooting was gettng more elaborate, and was slowing crippling any of the advanced features I wanted from the orbi (eg: wifi6) and stil not resolving the problem. For a premium device, it should not be this hard...
2) My orbi's would randomly reboot every day or two.
I really don't know whether the root cause of my issues was hardware, firmware or both, but I surprised and disapointed that it came this this. I would have hoped for better quality given the price point. On top of that only having 90 days free support I felt was very poor as well.
Phil.
- FURRYe38Oct 04, 2021Guru - Experienced User
Good Luck.
